GD Code on 740 R45TT
it codes out sometimes GD i Did Test I25 and I90 everything looks ok is driving me nuts...i need help..thx
  • Posted 27 Sep 2013 14:40
  • Modified 27 Sep 2013 14:41 by poster
  • By jay_o
  • joined 27 Sep'13 - 6 messages
  • Connecticut, United States
Just found this truck which had the same code. Make sure to check your steer motor brushes and commutator.
  • Posted 30 Mar 2018 08:33
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
Yeh steering amp did it ,thanks for all the info ,i forgot to come back and post what fixed it
  • Posted 23 Nov 2013 14:45
  • Modified 23 Nov 2013 14:48 by poster
  • By jay_o
Well O Jay, did ya get er fixed?
  • Posted 23 Nov 2013 14:29
  • By EasiTek
What year is this truck?
  • Posted 21 Nov 2013 09:19
  • By forktech418
  • joined 31 May'12 - 19 messages
The latest ver of software for your truck is VM 7.7 and Display 5.6. Updating your version can go along way in solving your GD issues.
  • Posted 5 Oct 2013 04:49
  • By forktech418
Ahhaha don't worry bro i got chu,i know what u mean some people don't appreciate *** ain't one of them i been working on raymonds for 5years and u know sometimes these codes could be pain in *** too many things could cause it to give u a code but in book doesn't tell u about you know what i mean ,i thank in advance for taking ur time.
  • Posted 30 Sep 2013 13:19
  • By jay_o
Steer card only gives code G4. Not the problem
Before doing anything, check radial ring wear. If worn, steer motor amps go up. GD code
if brushes are worn on steer motor, GD code. If toothed ring slips on drive unit, GD code
If steer prox is not even at full CC. CW turns, GD code, Stee prox adj clearence is.020 thou. Check it. If it's hitting the steel rail, Radial rings are shot
If steer motor spline slips, GD encoder fails, GD
If dog **** on right rear load wheel, GD code.
Good luck...let me know what you find...or...do like most people on this site, never respond and leave us hanging!
  • Posted 30 Sep 2013 13:11
  • By EasiTek
There isn't a good test for the steer amp. I recommend swapping it with another lift. I have seen this issue multiple times caused by the steer amp.
  • Posted 29 Sep 2013 05:04
  • By Raymond_Tech
  • joined 28 Sep'13 - 6 messages
Steering motor i took from diffrent lift that was not coding out installed it still same problem,r-rings are good the only thing i dont know how to check is steering amp and vm the lift is 09 year
  • Posted 28 Sep 2013 13:52
  • By jay_o
Even though the test for the steer encoder passes, the encoder still could be faulty. Also, if flash ware has not been updated recently, you might should try that. Raymond had a lot of issues with random GDs on earlier versions of flash ware. If you flash ware is current, I would put a new steer encoder bearing in it. If that doesn't fix it, it could have a faulty steer amp. Also, worn ring and **** could cause this code. Worn steer motor brushes could also cause it.
  • Posted 28 Sep 2013 13:40
  • By Raymond_Tech
Nils Altrogge Nils Altrogge
edition #1281 - 14 May 2026
F. Uchiyama
