Gasoline 4.3l vortec won't run
Has spark has fuel pressure at the test port but will not fire up tries to start with either but won't take off any help would be appreciated
  • Posted 7 Oct 2017 14:23
  • By kenneth_v
  • joined 7 Oct'17 - 1 message
Check the distributor. Pull the cap and check for excessive play in the shaft. We have had a number of these cause problems. After you pull the cap lift up on the rotor and check for excessive play.
  • Posted 9 Oct 2017 23:19
  • By BREWSKI
Hitachi HX64B2
Aichi SR10C1SM
