G2 code
I have a 2004 OPC 30TT getting a random G2 code. I have replaced the steer position encoder and harness, checked the prox switch for adjustment. When running learn the unit goes through the learn process without any problem. Where do I go from here? Please Help!
  • Posted 12 Aug 2011 21:07
  • By Walt
  • joined 12 Aug'11 - 5 messages
  • Maine, United States
I think I had this one once. It was the bolts that hold the drive unit in came loose or sheared off. When you would steer the truck to the left the unit would bounce back and set G2
  • Posted 18 May 2013 12:53
  • By Tomtech
  • joined 18 May'13 - 1 message
  • Illinois, United States
Thanks for the reply Joe, the ring gear seems to move freely, I will check the gear on the steer motor for play. I'll give you a little more info I found out today, it seems to only code when steering to the left past center steer indicator and will code while traveling or at a stand still. Could it be a mast cable ? Thanks again Joe
  • Posted 13 Aug 2011 12:12
  • By Walt
G2 can also be caused by binding in the ring gear or a loose steer motor gear.
  • Posted 12 Aug 2011 23:39
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
