Fuel not going past filter and solenoid
I have fuel going into the filter and not coming out of the solenoid. I have changed the whole filter and solenoid assy with no change. Need help asap.
  • Posted 16 Oct 2020 10:20
  • By curtis_b
  • joined 5 Jun'18 - 3 messages
That's what some people was saying
  • Posted 29 Dec 2020 06:42
  • By Andrew_Cuello
  • joined 18 Dec'20 - 5 messages
  • Hawaii, United States
AC
Glued??
  • Posted 29 Dec 2020 03:38
  • By Triggs
What needs to be glued in a regulator rebuild
  • Posted 29 Dec 2020 02:56
  • By Andrew_Cuello
AC
check to see if the injector is plugged with tar. I remove them and soak the tip in a cap of b12 or brake clean. You can also crank while doing this, if you dont see bubbles then its non operational
  • Posted 29 Dec 2020 02:21
  • By Triggs
I have fuel going to injector but not sure if the injector is firing. It has a hard time to start when it sits over night. Can spray Barkley into mixer starts up and runs fine. Anything you can help. Regular was just rebuilt but didn't touch the adjustment needle.
  • Posted 28 Dec 2020 06:33
  • By Andrew_Cuello
AC
So you don't have fuel getting to the regulator? Have you verified the main fuel solenoid is operational
  • Posted 24 Oct 2020 02:34
  • By Triggs
Aichi RX07B
Taylor T520S
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Aichi RX07B
Taylor T520S
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
