Freezer heaters not working
customer states that the truck quits working after about 30min in the freezer, and once it thaws it fine. I have B+ going to the F/C distribution board but nothing coming out to the heater resistors, the relay isn't closing when key is turned to the 'on' position, checked diode on F/C distribution board and found it open, anyone else had a similar issue? Not 100% sure this is gonna fix it but. ordered one.
  • Posted 2 Jul 2019 09:14
  • By Rgshock99
  • joined 11 Jun'14 - 8 messages
Rgshock99
wires are are good, turns out it was the fan behind the mast was bad. replaced it and works good. thank you.
  • Posted 17 Jul 2019 21:52
  • Modified 17 Jul 2019 21:53 by poster
  • By Rgshock99
Check thermistors are working, heaters will not come on until they are cold, disconnect wiring at them and short them together to turn on circuit path
  • Posted 12 Jul 2019 06:11
  • By dean_f
  • joined 10 May'19 - 6 messages
  • New Zealand
Did any of the heater wires get pinched in the multitask handle? Should have blown a fuse first
  • Posted 10 Jul 2019 07:34
  • By Ifixit
