Free lift cylinders will not lower
I have an SP-3400 that is stuck in the air the carriage cylinder is down but the free lift cylinders have about 5 or so feet of of ram extended,manual lowering valve does absolutely nothing. Any help would be greatly appreciated.
  • Posted 1 Dec 2014 00:07
  • By stucktruck
  • joined 27 Nov'11 - 17 messages
  • New Jersey, United States
Sorry, I missed your question and hadnt been back on this thread. Resetting a velocity fuse is as simple as lifting up past the point of trip. Fluid flowing back into the cylinder will reset it. Keep in mind that it tripped for a reason and this is a safety issue!
  • Posted 24 Dec 2014 04:26
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Thanks for the reply is there anyway to reset that because right now its getting a height switch sequence error because the platform is lower than the free lift cylinders.
  • Posted 5 Dec 2014 02:36
  • By stucktruck
Sounds like a velocity fuse trip to me. common on these if operator was hooked on a rack beam when lowering and had a quick drop. If this is the case I would be checking your slack chain sensor also if equipped.
  • Posted 3 Dec 2014 06:34
  • Modified 3 Dec 2014 07:12 by poster
  • By chevotaman
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
