Forward / reverse problem
Hi All,
Cat V50D diesel. Early nineties model - assumed. Peugeot XD3P engine.
Occasionally when having changed direction from forwards to reverse or vice-versa, when setting off from stationary the transmission 'bites' too low down the rev range making it hard work for the engine. Usually it revs higher as I suppose as it should.
I searched and found that the solenoids can be problematic but I don't know where they are. Could they be the cause ? What might I need to do ? or could it be something else ?
As usual, all help appreciated.
  • Posted 6 Mar 2019 10:16
  • By ratter
  • joined 2 Feb'19 - 9 messages
  • United Kingdom
I've had a look on the transmission and axle but I can't find anything in pairs that have cables leading to them. There's no pics on the net of the transmission or parts. I've sorted a battery charging problem and the clutch 'bite' is a tad better with a good battery that is being charged !!
Is the hydraulic circuit for the lift and tilt rams etc different to the circuit for the torque converter ?
Thanks in advance.
  • Posted 7 Mar 2019 02:15
  • By ratter
  • United Kingdom
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
Hitachi HX64B2
SMV (Konecranes) 4632CC5
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
