FORKS WON'T GO DOWN, NO TILT
Hey guys, i could use so help here...We have this Toyota 8FGU30 S/N# 14599. Seat light stays on as long as the red key in the dash but no trouble codes. The forks won't go down and we have no forward or backward tilt. Here is what we have done so far on the truck:
-CHECK SEAT SWITCH AND CONTINUITY : OK
-CHECK SEAT SWITCH WIRING. open circuit 1 to 5 volt: OK close circuit 0 volt: OK
-VERIFY CONTINUITY OF WIRING FROM SEAT SWITCH TO COMPUTER: OK
-CHECK ALL FUSES : OK
-REMOVE HYDRAULIC CONTROL VALVE AND CHECK SPOOLS, SPRING AND SWITCHES: OK
ANY IDEAS OF WHAT COMES NEXT???
THANKS IN ADVANCE FOR YOUR HELP
  • Posted 9 Apr 2015 23:23
  • Modified 10 Apr 2015 23:10 by poster
  • By LP35
  • joined 10 Aug'12 - 32 messages
  • Quebec, Canada
hello i know its been a while since you posted but by chance did you come across a solution for this issue. im having the exact same symptoms but on a diesel
  • Posted 23 Dec 2024 03:14
  • By izzy
  • joined 23 Dec'24 - 3 messages
israel hernandez
There is a 7.5 that operates the blade down and tilt in my case it keeps blowing just as I replace it any idea what is causing it
  • Posted 5 Jan 2020 02:11
  • By Swanson_Brown
  • joined 5 Jan'20 - 2 messages
Sbrown
Thank you
If you remember can you let us know. I'll start looking for hidden fuses.
Thanks Gary
  • Posted 26 Oct 2017 10:31
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
It was indeed a fuse. the thing is i don't remember wich one but it was a hidden one. hope this helps.
  • Posted 25 Oct 2017 23:16
  • By LP35
  • Quebec, Canada
I am having the same problem, did you find out the cause? any help would be great
Thanks
gary
  • Posted 25 Oct 2017 10:33
  • By mrforklift
Did anyone manage to figure out the issue? Im having the exact same problem and would appreciate some help. thx
  • Posted 31 Jul 2017 06:01
  • By InstaSean
  • joined 31 Jul'17 - 2 messages
To my I spend a 8fg30 and what damage were small springs carrying the control solenoid valve ( they broke ) at the bottom of control and caused the mast was not working nor inclination. Replace the springs and fixed the problem.
  • Posted 18 Feb 2016 09:43
  • By SIKA188
  • joined 18 Feb'16 - 4 messages
  • Cund., Colombia
Just ran into a similar problem and found the ecub fuse the issue. If you can get an analyzer to see if it communicates with anything, that would help.
  • Posted 10 Oct 2015 06:46
  • By rogeriwt
Check the electrical interface box under the step plate hasn't got wet / suffering from corrosion.
  • Posted 10 Oct 2015 06:07
  • By Forkingabout
  • england, United Kingdom
Hi
Did you manage to sort this I am having exactly the same problem
Many thanks
  • Posted 10 Oct 2015 04:00
  • By sean_l
  • joined 16 Mar'14 - 37 messages
  • Shropshire, United Kingdom
try checking all the fuses and relays. I have seem weird things happen when the relays stick or stop working.
  • Posted 11 Apr 2015 22:55
  • By rogeriwt
Noblelift
Enforcer FD50T-MMA
Autolift E180AT36B-D5-180
