Forks creeping down.
I have a problem with forks creeping down from any height.
Does not matter if running or turned off.
Just rebuilt main- free lift cylinder and still creeps.
Pulled out check valve in bottom of ram, cleaned and installed new o ring.
Still creeps down.
Both second stage cylinders were done several years ago.
When in full lift the two second stage cylinder will creep also.
No hydraulic leaks.
Anyone now what could be cause?
  • Posted 7 Oct 2020 02:43
  • By tdarr
  • joined 3 Dec'11 - 44 messages
tdarr@appi.us
some of the back cylinders have a piston packing at bottom of ram ,if that leaks by internally then that may cause problem , if the back cylinders have a hose, at top of cylinder take that off and see if oil comes out , if it does than repack the piston seal at bottom of rod , good luck
  • Posted 15 Jan 2021 00:49
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
I checked the return hose from control valve no fluid. the fluid is coming from a 1/4 id return line that runs down the top of the rear lift cylinder, supply line fron control valve goes to a junction block mounted on the mast, from there a line goes to the free lift cylinder and a second line fron the junction block goes to rear lift cylinder. so fluid from free lift to lower down is coming back to the junction block then down through the rear lift cylinder. i capped this 1/4 inch line and it solves the dropping issue but ofcorse the rearlift cylinder cant raise after max free lift, someone mentioned check valve where would this be? or any other ideas?
  • Posted 13 Jan 2021 08:33
  • By Douglas_Wright
  • joined 12 Jan'21 - 7 messages
Unless a cylinder is externally leaking thru the gland, it wont cause fork drift. You can check by raising forks and then removing the return hose that goes from control valve to the reservoir. If oil is coming out as the forks are drifting, then the spool valve, or relief valve like swoop said, has most likely failed. On old trucks i've had spool valves fail due to age and infrequency of oil changes. I've also found on several occasions an entire control valve is cheaper than the single spool. just a heads up
  • Posted 13 Jan 2021 02:24
  • By Triggs
I have the same issue after rebuilding lift cylinder both freelift and rear cylinder creeping down. Did you find your issue?
  • Posted 12 Jan 2021 08:57
  • By Douglas_Wright
sounds like relief valve in main control valve
if it is damaged or has any dirt in it or a weak or broken spring it can cause this
worse case scenario might be a bad lift/lower spool section
  • Posted 7 Oct 2020 10:03
