FORKLIFT WON’T START
I'm working on a TCM FCG15-3L. It will crank but never turn over. I've changed spark plugs, tested cam & crank sensor plugs & they have power. So, I put new sensors in.... It has a new battery. When I disconnected the propane, there were vapors so it seems to be getting fuel. I also changed the LP regulator and drained the vaporizer plug. Anyone have any suggestions?? ECU has been tested, as well.
  • Posted 9 Nov 2024 05:58
  • By Nachogirl
  • joined 25 Oct'24 - 4 messages
  • Tennessee, United States
Relay 1 and 2 are EGI relays. 1 supplys power to the ignition coils and the other supplys power to the ecm, Speed sensor unit and lpg injector drive unit... If im looking at the correct schematic that is.
  • Posted 15 Nov 2024 08:55
  • By BLey
  • joined 31 Jul'20 - 55 messages
Sorry. Terminology is my weak point. The solenoid & filter is what I meant. And drained the vaporizer. I was trying to confirm that fuel was traveling. Do you happen to know what those two relays are that are below the battery? (No wiring schematic.) I'm about to trace the wiring but I'm guessing they will go to the ECM & I still won't know what they are. I have not checked anything with injector so that is probably my next stop. At least until I get my hands on a schematic. Thanks for your input!
  • Posted 15 Nov 2024 07:58
  • By Nachogirl
Little confused as to your terminology when said changed regulator and checked vaporizer drain as the LP regulator and vapourizer are the same.
You should be able to find an OBD2 connector on the LH side near the battery under the hood that a common automotive code reader can hook up to.
Besides pulling codes there lots of basics you havnt mentioned like check fuses in fuse box, check inline fuse in the injector harness on the throttle body, check relays next to the battery especially relay 1 and 2, check for spark with a tester. Check vapourizer pressure (4.5psi to 6.5psi). Check for lpg leakage into intake (broken injector o ring or stuck assistant injector.) Check lpg pressure sensor and harness/connector in throttle body, Check compression, check for vacuum leaks.
Ive also seen a few harnesses rub through near the ECM connector that ended up breaking several wires.
Really you have to narrow it down more as to what your missing. Like is there no spark or no fuel.
  • Posted 13 Nov 2024 11:11
  • By BLey
Your assumption is correct. K21
  • Posted 13 Nov 2024 01:30
  • By Nachogirl
I cant remember but is this the K21/K25 or the H20/H25 engine?
Im assuming its a K21 because you said ECU and Cam and Crank.
  • Posted 9 Nov 2024 12:42
  • By BLey
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Columbia, SC, United States
Saratoga, United States
East Syracuse, United States
Enforcer FD50T-MMA
Crown WP302020
