Cat Lift Trucks (& Caterpillar) E6000:
Forklift won’t lift past the first stage
Electric forklift won't Lift past the first stage with 2 loads(it has a single double attachment). Any ideas? I'd appreciate it
  • Posted 8 Dec 2022 16:25
  • Modified 8 Dec 2022 16:25 by poster
  • Discussion started by Kevin_D
check the main relief pressure, should be 2630psi.
if that checks ok then i'd pull the center cylinder rod assy out and check the safety valve in the base of the rod, they are bad about coming apart and causing many lifting and drifting issues.
  • Posted 10 Dec 2022 23:47
  • Reply by swoop223
Louisville, KY, United States
Dubuque, IA, United States
edition #1228 - 1 May 2025
Toyota 8FD45
Toyota 02-8FD30
UN Forklift FB25N1QZ1
Toyota 8FG25
