Forklift won’t lift past the first stage
Electric forklift won't Lift past the first stage with 2 loads(it has a single double attachment). Any ideas? I'd appreciate it
  • Posted 8 Dec 2022 16:25
  • Modified 8 Dec 2022 16:25 by poster
  • By Kevin_D
  • joined 9 Sep'22 - 3 messages
check the main relief pressure, should be 2630psi.
if that checks ok then i'd pull the center cylinder rod assy out and check the safety valve in the base of the rod, they are bad about coming apart and causing many lifting and drifting issues.
  • Posted 10 Dec 2022 23:47
Hawker Powersource, Inc.
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
