Forklift starts but does not move
Hello, I have a Yale Veracitor 25vx fitted with an FE engine.
Serial number B875B14638E000FF
the machine starts. When I try to put it on forward or reverse a spanner symbol will show on the dash and the machine goes back to neutral. On the dash it also show code 523930-3
Any help please?
  • Posted 31 Dec 2024 05:23
  • By OwenMallia
  • joined 31 Dec'24 - 1 message
  • Malta
Owen Mallia
Owen,
Clutch FWD1/Return Coil Driver OORH (Powershift Transmission Repair). Since it is out of range high, suspect bad connection at valve or a failed harness. Check all connections for corrosion, bad pin socket fitting or broken wires. The circuit is not complete which shows higher than what the voltage should read. Good Luck.
  • Posted 7 Jan 2025 02:26
  • By Fishmech
  • Virginia, United States
