OM Pimespo EU3/15:
Forklift problem
I have a problem with a forklift.When i take the forklift from charging and after a while turn the key off and then back on battery indicator drops 10-20%.Every on-off indication drops 10-20% until the truck gives error.Battery checked-good,Charger checked-good.Any ideas?
  • Posted 20 Jul 2013 02:50
  • Discussion started by tasos_t
  • ATTICA, Greece
The correct battery voltage need to be programmed into the truck control system. The control panel needs to be set to allow programming in the first instance but a simple press of a few keys after will rectify this. If you still have the problem let me know and i can walk you through it. Will need truck serial number for this.
  • Posted 28 Sep 2017 21:32
  • Reply by Dez_A
  • Middlesex, United Kingdom
Service life of a forklift is proportional to how well it is maintained.
I had the same problem, battery works well on other machine, now indicator says battery discharged and will not lift.
Anybody any ideas or copy of manual please
Regards
  • Posted 13 May 2016 20:03
  • Reply by gary_f
  • Malaga, Spain
edition #1228 - 1 May 2025
Dubuque, IA, United States
Louisville, KY, United States
