Forklift doesn't move forward or reverse.
Hi,
Our Raymond 20R40TT doesn't move forward or reverse. We have troubleshoot and we can't find the problem. Is there anyone who has already face this kind of issue or anyone who could link us a service manual, wiring diagram, or some helpful infos please?
Thanks!
  • Posted 27 Feb 2015 04:01
  • By Dominic
  • joined 27 Feb'15 - 6 messages
  • Quebec, Canada
Showing items 1 - 18 of 18 results.
Dear sir Or Madam
How did you fix this problem i have the same problem on My reach truck (bendi type)
my email is [email address removed]
  • Posted 17 May 2022 00:25
  • By bidda_Samuel
  • joined 17 May'22 - 1 message
  • Uganda
bidda
send me schematic too please if you got it.020-r30tt raymond thanks
  • Posted 12 Apr 2022 10:20
  • By david_P
  • joined 12 Apr'22 - 2 messages
  • Virginia, United States
david p
need schematic or trouble shooting guide please, just got from auction 020-r30tt raymond forklift for my shop. hope you acquired one and will to share it. both pumps turn on with forks, nothing when tram lever engaged either direction. no light in red control box. scr's read good didnot gate them diodes read as should contacts look good.to lazy to trace wiring if i dont have to. any help greatly appreciated. first time looking at one of these
  • Posted 12 Apr 2022 10:10
  • By david_P
david p
Do you have a schematic for this model # ? I realize its a old post. Just need schematic on this old unit.
  • Posted 28 Jul 2020 08:38
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
send me, please
  • Posted 10 May 2020 01:26
  • By khanhvy
  • joined 18 Dec'19 - 1 message
  • Viet Nam
D?y h?c lái xe nâng giá r? uy tín ch?t lu?ng
Mail: adhocxenang@gmail.com
Website: hocxenang.com
if your only pushing in one contact and the motor is moving your high speed contactor is welded or scr1 is shorted.
  • Posted 28 Feb 2015 05:29
  • By stam
Check the small micro switch on the top of the drive motor. the brake pedal activates the master cylinder and turns on the switch.. common problem. and/or wiring to the switch
  • Posted 28 Feb 2015 01:50
  • By Prentice
Click on my user name and it shows email
  • Posted 28 Feb 2015 01:48
...can you give me your email adress? I'll send you a picture of how we test it.
  • Posted 28 Feb 2015 01:34
  • By Dominic
  • Quebec, Canada
You have to explain in more detail what you are doing to test it. Are you just pushing one solenoid with one finger and the motor runs? Is it running full speed?
  • Posted 27 Feb 2015 09:01
Yes, with a finger. And it works until I remove it and so, on forward and reverse position.
  • Posted 27 Feb 2015 08:42
  • By Dominic
  • Quebec, Canada
How do you by-pass the control solenoid? Push it with your finger? Then what, does it stay in and travel until you stop and try to go again?
  • Posted 27 Feb 2015 08:21
Yes, power steering and lifting work fine, and drive motor too if we by pass the control solenoid.
  • Posted 27 Feb 2015 07:55
  • By Dominic
  • Quebec, Canada
Does the power steering and lifting work ok? If so, the drive motor may be so dirty or gounded that it won't allow it turn on. You should unplug the battery and check the resistance from the power plug on the forklift to the frame, both positive and neg. It should be at least 100,000 ohms but if it gets down below about 20,000 ohms it won't turn on the drive. If that shows a ground, you could try washing the motor with electric cleaner and blowing it out.
  • Posted 27 Feb 2015 07:44
Yes it is!
  • Posted 27 Feb 2015 07:10
  • By Dominic
  • Quebec, Canada
Is this a old lift with a black box type of controller under the cover to the right of where you stand on it? If so I have some info on that model.
  • Posted 27 Feb 2015 07:05
The only gauges on dash are battery level and hourmeter. Nothing flashes. Is there a way to upload images in the discussion?
  • Posted 27 Feb 2015 05:18
  • Modified 27 Feb 2015 05:21 by poster
  • By Dominic
  • Quebec, Canada
Any codes on the dash display??
  • Posted 27 Feb 2015 05:00
  • By Prentice
Esie Cortez Esie Cortez
