Linde (& Baker) E16C-02:
fork carriage problem
TRIPLEX MAST, free lift
When lifting fork carriage (at high speed) it jams somehow and force to lift inner mast. than when you stop lifting this inner must falls down.
I cleaned and lubricated mast rails, rollers are OK, space RS is a little too much....but i think it is better much then less...
What else can be wrong? any experience?
thanks
  • Posted 11 Jan 2016 07:02
  • Discussion started by TANTADRUJ
  • ljubljana, Slovenia
Showing items 1 - 15 of 15 results.
check the seals by all means but if this is a fluid displacement cylinder then there are no seals on the ram, they are all in the packing nut on top of the cylinder shell where the ram comes out.
You are going to have to remove the cap/packing nut anyway to get access to the inside of the freelift cylinder so once you do this remove the ram and look in the base of it and check the safety flow valve. Make sure it is there and intact, if it is not then it may have come apart and is laying down in the bottom of the cylinder in smashed up pieces.
I have see quite a few of these do the exact thing you speak of and pretty much always it was that safety valve causing a misstaging problem. Usually caused by the snap ring failing that holds the valve in.
  • Posted 9 Oct 2016 14:18
  • Modified 9 Oct 2016 14:19 by poster
  • Reply by swoop223
Its called mis staging. Freelift cylinder may have bad inner seal
  • Posted 9 Oct 2016 12:55
  • Reply by edward_m
it's indeed strange
  • Posted 29 Jan 2016 06:39
  • Reply by marcb
  • ANTWERP, Belgium
Hi, it has to have it. I did not remove it....and some time works just fine, than in next 20 min wont work.....strange.....
  • Posted 29 Jan 2016 06:24
  • Reply by TANTADRUJ
Hey Tantadruj, just an idea can you control if the free lift cylinder has got a down safety valve sometimes it's inside the cylinder or on the outside nipple.
Reagrds
Marcb
  • Posted 29 Jan 2016 06:15
  • Reply by marcb
  • ANTWERP, Belgium
Thanks Adams1
I'm also thinking about air in cylinders....
Can you give me a part number of pressure valve? Are you thinking about line brake safety valve? Can you show me on the picture....
  • Posted 29 Jan 2016 03:11
check for a pressure valve going to the primary lift cylinder. sounds like its weak and sending oil to the secondaries as well
  • Posted 28 Jan 2016 22:11
  • Reply by Adams1
  • Indiana, United States
It's not good! the same problem.....I don't know what else to do?
The main hose is original, oil 32, rollers are good, mast is clean....
Only appears when fast lift.....
  • Posted 28 Jan 2016 07:03
Tantadruj, thanks for your reply.
Regards
Marcb
  • Posted 16 Jan 2016 02:40
  • Reply by marcb
  • ANTWERP, Belgium
Problem solved. I changed oil (repsol 32) and now works just fine..... I'll also try with Repsol 46....
Thanks for all suggestions.
  • Posted 16 Jan 2016 02:15
Check if the lift cylinder is in the right place maybe you remove both
cylinder and when you return it it was swoop. If this will happen this
problem will occur.
Best regards,
Rolly
  • Posted 16 Jan 2016 01:16
  • Reply by rolly
  • Manama, Bahrain
rollbes2003@yahoo.com
Hello Tantadruj; we've experienced that when the diameter is to small the oil flow isn't correct.
Don't know exactly what it must be, we had that problem whit a Komatsu.
I'm not saying that hose diameter is your problem it is just an idea and we experienced that in the past.
I'll hope you can solve your problem.
Kind regards
Marcb
  • Posted 13 Jan 2016 02:56
  • Reply by marcb
  • ANTWERP, Belgium
Thanks for help.
I will change oil.....
I don't know about hose, will ask.....what size has to be? If it's bigger can be problem, to much oil at the time....
  • Posted 12 Jan 2016 08:26
  • Modified 12 Jan 2016 09:06 by poster
I ones head the same problem. The oil was to thick.
I changed the oil to Valvoline HVLP 32.
and there where no problem after.
  • Posted 12 Jan 2016 07:59
  • Reply by sjoold
  • Norge, Norway
Hey Tantadruj, has somebody changed a hose of the free lift cilinder? we had the same problem in de past, somebody changed the hose but the inside diameter was wrong so at high speed it lifted the 2 outside cilinders as well.
Regards
marcb
  • Posted 11 Jan 2016 17:09
  • Reply by marcb
  • ANTWERP, Belgium
edition #1234 - 12 June 2025
Load Lifter 2414-8G
Flesherton, Ontario, Canada
Hangcha CPYD25XW71F-JC
