Faults Codes
Can anyboby help with those codes on a LP H60FT
Thanks
651-5
652-5
653-5
654-5
522631-2
522752-9
  • Posted 12 Mar 2012 22:20
  • By DOUMINQUEBEC
  • joined 28 Sep'11 - 6 messages
  • Quebec, Canada
Thanks
Will check that, we are very appreciate the help.
Dominique
  • Posted 13 Mar 2012 12:19
  • By DOUMINQUEBEC
  • Quebec, Canada
The 651,652,653,654 codes are indicated for the Cummins diesel engine, They mean nothing to the LP engine.
522631-2 is O2 sensor failing to switch to lean, checks wires at connector, between pos. and grd. should be 5 volts, if not check between pos and frame, if voltage present grd wire broken, if yes, could be faulty O2 sensor.
522752-9 is cam sensor, test in same fashion as O2 sensor, if voltage is present, sensor may be faulty.
  • Posted 13 Mar 2012 11:32
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Nagano NUL120-6
Still GX10
Still GX10 2000
Poland
EUR950
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Nagano NUL120-6
Still GX10
Still GX10 2000
Poland
EUR950
