FAULT MELDUNG A57
CLARK CTM16S ELECTIC 3 WHEEL FORKLIFT. CLICKING AS IF IT IS A MOTOR PROBLEM.SHOWING UP ON INSTRUMENT PANEL MELDUNG A57.ANY SUGGESTIONS,MANY THANKS.
  • Posted 27 Jun 2006 08:11
  • By jelly400
  • joined 27 Jun'06 - 3 messages
  • Co. ANTRIM, Ireland
MANY THANKS DAVE, jelly400.
  • Posted 14 Jul 2006 05:10
  • By jelly400
  • Posted 14 Jul 2006 04:57
  • By jelly400
Hi jelly400, A57 is a problem with a contactor, if you count the "clicks" you will count 10 fast clicks, which means that the contactors cycle 5 times. If it does this in either direction it is the TFR (Regen) contactor the (small one) If it happens in only one direction it is the contactor assosiated with that direction. You need to strip and replace the contactor tips. Meldung on the instrument panel means it is set to a foreign language. You need to change this by pressing the light button and holding it while switching the key on. Then put in the code 2085 with F1 or F2 entering each digit with the light button as you go. Then select language and change it to English. Press and hold the light button to enter it. dave
  • Posted 11 Jul 2006 07:56
  • By DaveUK
  • joined 12 May'06 - 44 messages
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
Linde Material Handling
Muncie, IN, United States
Kai von Berg Kai von Berg
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Ice 24INCH-AUTO-SCRUBBER
USD6,396
