Hyster W45Z:
Fault Code
i am experiencing a fault code FLT 30069 Pre charge on the main display. there is no alarm number corresponding to this code being displayed. looking for advice on where to start troubleshooting. fork truck is not operational with this code being displayed.
  • Posted 17 May 2019 10:26
  • Discussion started by kenneth_w
  • Newfoundland and Labrador, Canada
DTC 30069 (Cont) Precharge
CAUSE A - CONTROLLER WIRING FAULT PROCEDURE OR ACTION: 1. Measure voltage between the traction controller B(+) terminal and B(-). Is precharge voltage same as battery voltage? YES: Proceed to Cause B. NO: Check for external loads or shorts on the B(+) circuit and phase cables. Refer to the Basic Electrical Troubleshootingsection and perform Voltage Checks. CAUSE B - FAULTY TRACTION CONTROLLER PROCEDURE OR ACTION: 1. If no faults are found, replace controller. Make sure to indicate the DTC code(s) on the warranty claim to include an accurate problem description leading to controller replacement
  • Posted 17 May 2019 22:07
  • Reply by BREWSKI
edition #1229 - 8 May 2025
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
