Fault code
Hi experts
I have a NOR30P Caterpillar does not. failure indicates "C1" and 84
I found the locked brake, I guess so, did not detect the initial movement encoder.Code 84
Someone can spend fault codes this truck.
Regards
Edgardo
  • Posted 28 Oct 2016 06:44
  • By edgardo_a
  • joined 26 Feb'09 - 28 messages
  • canelones, Uruguay
code C1 is 12v power supply failure
reason is 12v is not being sensed at the steer controller
system response is:
horn sounds
display shows C1 (check battery)
speed limit: 0.0mph (dump brake occurs)
code on steer controller card appears as C 1
if you look under hood on tractor unit you will find microcontroller on right hand side, the steering controller will be mounted about center of the truck on same shelf microcontroller is. It will have cables and several harness connectors going to main harness and down to drive motor and steer motor area, they will be connected to the steer motor and one cable will be connected to microcontroller.
the display on the steer controller is 2 LED windows and both will show a C1, you may also see a C1 on the microcontroller LED display.
check on the steer controller to see if the 12v LED on the controller is on.
if code is intermittant you may need to run maintenance test A50 to check steer controller supply voltage test.
also first and foremost check the battery voltage, run a load test to see if battery is holding up well, if there is severe voltage drop then battery may be causing the problem.
  • Posted 29 Oct 2016 08:24
Thanks swoop
The code 84 is solved, now indicates C1. That failure is C1?
You may send me complete list of code failure?
Regards
Edgardo
  • Posted 29 Oct 2016 00:46
  • Modified 29 Oct 2016 01:07 by poster
  • By edgardo_a
check the brake switch on the side of the drive motor for proper adjustment, if it does not unlock the brake when the deadman pedal is pressed it will code out if the brake does not release during the self test and allow for the drive encoder test when it pulses the drive motor.
  • Posted 28 Oct 2016 23:48
Linde Material Handling
