Mitsubishi FB20KT:
Fault Code "Lo"
Has fault code Lo right after turning key on. Found out code means battery consumption too much. What does this mean???
  • Posted 2 Oct 2020 00:45
  • Discussion started by MikeHLT
  • Michigan, United States
yes it means the battery voltage is low
when the line contactor is closed the system is seeing voltage below 22v.
the logic card needs to see correct battery voltage at connector pin locations CN2-34, 39, 40, 41, 42.
have your battery tested and make sure all the cells are ok, a couple of bad cells can cause a severe drop triggering this code.
  • Posted 6 Oct 2020 07:38
  • Reply by swoop223
Usually means the system detected battery voltage below 22v.
  • Posted 6 Oct 2020 05:39
  • Reply by BLey
Linda Häkkilä Linda Häkkilä
Taylor TT300
USD98,500
Terberg YT182
UN Forklift FBRS15KQZ2
Taylor THC500L
VETTER Forks, Inc.
Dubuque, IA, United States
Louisville, KY, United States
