Fault code help
Hello,
We have a Yale GLP040VXNVSV101 showing a fault of 522592-0. Our warehouse is 2 1/2 hours from closest mechanic and just want to find if it's a major issue. Also, if not to much trouble could anyone give me mfg year as we inherited this machine. Serial number is as follows B875V01557F. Thanks in advance for any and all help.
  • Posted 2 May 2018 08:41
  • By Okie
  • joined 2 May'18 - 4 messages
  • Oklahoma, United States
Worlds ok'est welder
The code will clear itself after the problem is removed.
  • Posted 10 May 2018 01:04
  • By BREWSKI
Thank you very much. If our mechanic can find issue in regulator will a tech still have to come clear code? I am not familiar with these machines at all.
  • Posted 10 May 2018 00:43
  • By Okie
522592-0 EPR Pressure Greater Than Commanded. Sounds like a regulator problem. Your truck is a 2008.
  • Posted 2 May 2018 22:11
  • By BREWSKI
GemOne
