Unicarriers (& Nissan) MVGLO-02A35LV:
fault code e 27
what is this code
  • Posted 23 Sep 2009 04:45
  • Discussion started by curt_s
I know this is an old post but also look for a misfire. while E-27 is a crankshaft position sensor code, it is often caused by a misfire from things like a bad coil, spark plug, tight valve, etc. It could be in the crank position sensor circuit but the misfire is a more common cause.
  • Posted 18 Mar 2011 02:04
  • Reply by WMC1
Crank Position sensor.
How does the truck run?
If it won't start or goes into " limp home Mode" look at the sensor. if it runs poorly but you can rev up the RPMs check the plugs and coil packs.
  • Posted 23 Sep 2009 13:55
  • Reply by roadtech
Taylor TE650S
Ncn 85TH
Ncn 85TH 2017
