Fault code 9024
Hi got fault code 9024 no services
Truck energise and power steering and hydraulics work unit you go to drive as soon as contractor comes it it drops everything and gives you the spanner will reset upon restarting says it's the left hand motor control any ideas where this is as does anybody know the part no of it please ????????
  • Posted 7 Dec 2022 03:37
  • By keith_t
  • joined 3 Nov'09 - 102 messages
  • essex, United Kingdom
Keith,
I assume you have found what you need. The controllers will be located either under the floor boards or on the counterweight. Verify all connections are good for the motor cables and wire harness. Controllers do not fail often. Low battery voltage over multiple weeks will over heat them. Good luck
  • Posted 23 Dec 2022 04:04
  • By garland_m
  • joined 16 Oct'09 - 225 messages
  • Virginia, United States
Work Hard and Fish Long
