Raymond 152OPC30TT:
Fault Code #81
When lowering the forks an alarm sounds and a code "81" comes up. Machine operates normally other than that. Appreciate any help.
  • Posted 8 May 2009 06:32
  • Discussion started by cfpc
for the EASI orderpickers code 81 is for the lift pot out of range
unfortunately you need the "superword" for the unit to calibrate it if you need to replace or adjust it
make sure the mechanical parts for it arent damaged
  • Posted 8 May 2009 22:38
  • Reply by justinm
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
