Fault Code 522761-6
Engine quits running or & shuts down hyd mini lever functions with code displayed.
Restart & run until it codes out,then shuts down engine.
  • Posted 5 May 2015 08:13
  • By Horse
  • joined 11 Jan'11 - 38 messages
  • Wisconsin, United States
Jeff Bykowski
Well I noticed it shutting down when the seat was bouncing. Investigated & found mini lever wiring harness under suspension seat was routed improperly & caused pinch in harness which had worn through & shorted out. Problem fixed.
Thanxs for the help
  • Posted 8 May 2015 23:57
  • By Horse
Jeff Bykowski
Its my own rental unit so nothing has been altered. I ll have to look @ harness for shorts to frame. Would you agree?
Switched batt current meaning. Anything powered from ignition side of ignition switch?? Which is relayed @ fuse board?
  • Posted 6 May 2015 00:13
  • By Horse
check for shorts to ground, and also if someone has added _any_ device that was not 'factory" (backup alarm, strobe or lights included). 522761-6 is Switched Battery Current 2 (IGN 2) Current Too High OORL
  • Posted 5 May 2015 22:00
edition #1295 - 20 August 2026
In this week’s Forkliftaction News, we look at the US ban on humanoids, what it means and why some analysts believe it has been introduced to stymie Chinese imports... Continue reading
The Horsey Horseless was an early automobile prototype invented in 1899 by Uriah Smith, a Seventh-day Adventist preacher, in Battle Creek, Michigan. A wooden horse head and neck was attached to the front of the vehicle, as it was believed to prevent frightening horses on the road.
September 8-9, 2026 - Barcelona, Spain
November 10-12, 2026 - Marina Bay Sands, Singapore
