Crown RR5210-35:
Fault Code 222
Re-entered by Admin on behalf of tom p.
This truck will just start (sometimes) then the line contactor drops out and fault code 222 appears,(drive motor short) The service manual troubleshooting procedure requires a service password be entered in the display panel to start the diagnostics. Has anyone.......advice on resolving 222.
  • Admin
  • Posted 20 Jul 2012 12:55
  • Discussion started by Admin
  • Queensland, Australia
sorry armando but there is no lube for motor brushes.
you can clean up with contact or motor cleaner to remove brush carbon buildup or dirt making brushes stick but that is about all you can do.
putting lube on brushes is the worst thing you could ever do.
when you remove them check for wear, if worn replace them.
this is the only thing to fix stuck brushes.
clean or replace or both.
  • Posted 9 Mar 2023 10:15
  • Reply by swoop223
Thanks is correct is the brushes stuck
Just add some lube to make lose and start up
  • Posted 9 Mar 2023 08:01
  • Reply by armando_g
grgarryciencia@aol.com
Code 222 Means M2 Lift Pump Motor Open Circuit. most of the time its the Brushes worn out or it is stuck inside the holder. other than that check for loose connections within the circuit, contactor tips, and fuse.
Hope this is helpful
Regards
Ram
  • Posted 4 Jun 2021 05:36
  • Reply by Ramdeo
  • Netherlands Antilles
Ram
ramkhudan@gmail.com
Hi how to solve this problem the battery is
36.4 volts and use the lift go to 27 And
The code come on 222,832,416 thanks
  • Posted 4 Jun 2021 04:08
Thanks for your help (though this appreciation is ironic because nobody ever answered me my emails and comments).I document the problem related to error code 222 (Crown RR5000 series) to help someone diagnose the fault because I do not want to be selfish with the knowledge I acquired these days.I commented that fails M2 detect when the engine turned, but not expelled fluid. We initially that was broken shaft or the pump is worn inside but the failure was that the spline shaft of the pump (which is coupled to the motor) was totally worn, moisture apparently originated or other factor that the shaft oxide and eventually wear severely. We replace the pump with a new one and problem solved. Additional topic that is important to state that gave us clues to the origin of the problem was when I measured the current feeding the motor M2 is rising much for normal parameters.
  • Posted 6 Jan 2013 03:19
  • Reply by oscar_r
  • Lima, Peru
the 24volt RR5000 is notorious for the brushes sticking in the holders. make sure each brush is free to move. any that are tight remove and sand sides down a little
  • Posted 21 Jul 2012 15:56
  • Reply by crownie
  • Victoria, Australia
key points to check
- power or control fuse blown
- motor brushes
- contactor (if contactor controlled)
- power and control wiring to motor
worse case scenario would be the controller that signals the circuit may be defective
the system does a self check during startup, if it sees any problem it shuts the system down.
  • Posted 21 Jul 2012 00:08
  • Reply by swoop223
Code 222 is for Pump M2 motor open circuit,if you have an email to post in your profile might help if someone needs to send you any info that they may have.
  • Posted 20 Jul 2012 21:01
  • Reply by kevin_t
edition #1130 - 1 June 2023
You might notice a few changes in your newsletter and on our website. That’s because we updated the format last week to make it even easier to read – and to... Continue reading
Natasha Solano-Vesela Natasha Solano-Vesela
global airfreight director - perishables, Hellmann Worldwide Logistics
COO, Clark Material Handling Company
BDM, Clark Europe
CEO, DHL Global Forwarding
Louisville, KY, United States
Miami, Florida, United States
Decatur, IL, United States
Inver Grove Heights, MN, United States
May 15-17, 2024 - Singapore, Singapore
July 19 - 21, 2023 - Bangkok, Thailand
September 26-28, 2023 - Houston, United States
Waco, TX, United States
SMART ATTACHMENTS
Mar 2023
DRIVERLESS/AUTOMATED MATERIALS HANDLING
Apr 2023
