Checked out the sensor, apparently the wires were exposed right at the connector. repaired the connection and haven't had an issue since. Thanks for the help!
Better to troubleshoot the sensor then just chnage parts IMO.
But yes, it would be due for a trans service.
Be sure that the trans case breather is clean as well.
Just noticed the unit has just under 2000 hours since last trans service. You thinkit might just need a service or change out the sensor?
check transmission temp sensor.
