fault code 10
when i start the fork lift up, 10 comes up on the display. it won't drive or do anything. I hope this is an easy fix.
  • Posted 17 May 2012 03:59
  • By chad_w
  • joined 17 May'12 - 5 messages
  • Minnesota, United States
chad,
are you an operator or a technician?
my guess is operator..
checking switches is basic electric 101 stuff
i suggest you call a service tech out if you are not familiar with these things.
  • Posted 19 May 2012 00:11
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
where can I find what the fault codes are for my truck?
  • Posted 18 May 2012 13:07
  • By chad_w
Can I jump the switch because the 4th spool is not used or jump the switch to see if it is the switch that is the problem. I looked at the 4 switch and it doesn't look to be out of adjustment. The 1st and 2nd spool is for the up/down and tilt. 3rd is for the left/right. I don't think I have ever used the 4th spool for anything.
  • Posted 18 May 2012 13:06
  • By chad_w
I bought a service manual on the truck. How can I tell if it is out of adjustment?
  • Posted 18 May 2012 11:44
  • By chad_w
chad,
yes there is a service manual on this truck but i'm not at liberty to give that out, sorry.
if you check the switches on the hydraulic control valve on the 3rd and 4th spools you will find one of those most likely out of adjustment, check the last function switch, this is aux2 i believe.
When the truck does its self check on start-up it is detecting a problem with one of those switches probably being closed during the check. If this is the case the truck will not pass the start-up check and code out the code 10 and prevent the truck from starting up.
  • Posted 18 May 2012 10:23
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Is there a repair book out there so that I can see what I'm looking for?
  • Posted 18 May 2012 09:00
  • By chad_w
aux2 switch defective
check your hydraulic switches on control valve
  • Posted 17 May 2012 21:16
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
