Fault 61
Hi out there.
Can anybody help with a bit of guidance about my 61 fault.
Got no fwd/rev or hydraulics and my in line contactor won,t close.
Checked the usual suspects ie fuses, direction lever, handbrake micro, acc pot, seat switch , and battery. Looks like its got diagnostics but don,t know the correct sequence.
Thanks
Kev
  • Posted 5 Nov 2013 06:47
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
Hi
Did anyone get sorted with this?
I've put a new logic board into machine, using the truck tool software, the parameters went seem to save to truck
Please help
Many thanks
  • Posted 27 Jun 2024 23:01
  • By Peter_Hughes
  • joined 26 May'22 - 5 messages
  • Ireland
PD Lift Trucks
Problem: Traction EEPROM, Abnormality (61)
Now to explain how this code is triggered:
When logic software starts, first it reads the Setup Option data and those check sum data from EEPROM. Software
compares both data. When there is difference, error 61 occurs.
Checks
Set Setup Option Group 3 data. Then, set Setup Option Group 1 and 2 data (default data).
If necessary, adjust Setup Option Group 1 and 2 data again.
See pages in manual for (Procedure of "Setting Setup Option Group 3", "Setting Setup Option Group 1 and 2 default data" and "Adjusting Setup Option Group 1 and 2")
Once you complete checking and resetting up the data in the setup options recheck operation
if "61" display remains?
replace traction logic board
so basically what prancer said ;o)
  • Posted 23 Mar 2014 22:01
The code says its the Traction controller, In the rear panel you will see a large Box or two, the one on the left is the traction one, remove the plastic cover and inspect it for burns, they get hot if the driver pushes with the lift. I just repaired a unit with this code. It wasn't either controller but, the small control card that attaches to the it.
  • Posted 15 Mar 2014 11:14
  • By Prancer
  • joined 12 Oct'13 - 48 messages
berwinten@msn.com
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
Taylor TT300
Terberg RT403
