Fantuzzi transmission Problems Need Help!!!
I have a Fantuzzi FDC25 empty container Handler that when it operates in gear going forward it throws itself in neutral and it only works again once you shut it off and re start it again. I heard Fantuzzi units are known for these kind of problems but I do no have a solution. can anybody help?????
  • Posted 20 Sep 2008 11:06
  • Discussion started by fernando_a
I do not have a solution for your trans problem, but I wanted to let you know that my company has a large stock of parts for the Fantuzzi line of equipment, including your FDC25.
You might want to visit the site and register for the newsletter.
www.railportparts.com
  • Posted 12 Mar 2009 01:21
  • Modified 12 Mar 2009 01:22 by poster
  • Reply by RS50partssupply
  • Indiana, United States
Visit www.railportparts.com
If there is an interlock device, there should be a proximity sensor on the prop shaft or gearbox output shaft, and the control unit will be housed with the rest of the control relays etc.
  • Posted 24 Sep 2008 05:09
  • Reply by AndyPandy
Do you know where this device may be at??? I also noticed in the squematics that there is a engine safety device switch that may also take the unit to neutral but i can't find it.
  • Posted 21 Sep 2008 03:49
  • Reply by fernando_a
Check if there is a prop shaft sensor/interlock fitted and that it is working correctly. These types of machine usually have some form of interlock device which prevents you changing direction whilst the machine is still moving. When this device is faulty you often get symptoms similar to the ones you describe.
  • Posted 20 Sep 2008 19:53
edition #1228 - 1 May 2025
