FAN BELT REPLACEMENT
Does anybody know how to replace the fan belt on the Nissan 80 forklift which has the TB42 motor in it? I can see that it has 3 seperate belts on it- Alternator- Fan- Governor- but all is needed is the Fan belt which has been broken off. There is a shaft attached to the Crank pulley with 4 bolts that goes to the hydraulic pump-I think- cannot see too well inside the compartment- does this shaft come off or seperate from the crank pulley easily?
  • Posted 23 Oct 2009 00:18
  • By ray_s
  • joined 2 Oct'09 - 58 messages
  • Alberta, Canada
You should be able to block the truck up at the steer axle and gain access to the crank pully from the underside, If your going to this much trouble, you'd be better off in the long run to replace all of them at the same time, 'cause sure as the sun will come up tomarrow, the altenator belt will break next week. Just remove the 4 bolts and slide the coupler shaft twords the Hyd. pump, you'll have to remove the alt. belt to install the new belt anyway.
  • Posted 23 Oct 2009 13:28
  • By roadtech
On forklifts with the pump run off the crankshaft you have no choice but to unbolt the shaft to get the belt on. After removing the 4 bolts it should move out of the way enough to get the belt on. I'm not sure about how much room there is to get at the bolts on your model, maybe have to take the counterweight off.
  • Posted 23 Oct 2009 12:56
Mitsubishi FD200
Unicarriers FD80-2
GemOne
Esie Cortez Esie Cortez
GemOne
GemOne
