F-16 code
Machine is throwing an f-16 code. Unit starts and runs fine but won't go into gear. I've found that the code means shift lever error. Wondering if anyone has encountered this and what could be the solution. Not sure yet if I need to replace the shift lever of if it's more involved. Thanks in advance.
  • Posted 4 Nov 2015 09:30
  • By Davies
  • joined 18 Apr'15 - 17 messages
Just wanted to let you know that we found our issue. We found a couple of wires going into the controler that had been chewed by a rodent. One wire was chewed at the controler plug and the other end of the wire was chewed right at the harness loom. Hope this helps.
  • Posted 6 Jan 2016 07:11
  • By Tech16
  • joined 4 Dec'14 - 8 messages
I was following your post. Were you able to solve the issue? I'm experiencing the same thing.
  • Posted 5 Jan 2016 10:32
  • By Tech16
Hour meter shows up just fine. After changing it the unit ran fine for about 45 minutes then started doing the same thing. Havenr recently installed a backup alarm, just has the original one.
  • Posted 17 Nov 2015 02:24
  • By Davies
at this time, after changing the f&R switch, does the hour meter ever show the hours after it starts, or does it just show this error? did it make any change at all?
f16 indicates both directions are sending the same signal to the computer for over 2 seconds..
did someone install a back up alarm?
you may be going to check 'pin to pin' from the directional switch to the ECM.
  • Posted 14 Nov 2015 11:01
Well, changed fnr switch, changed oil and cleaned strainer (barely anything in it) and have traced all electrical. Checked all safety switches...can't figure this one out. Any advice would be greatly appreciated.
  • Posted 14 Nov 2015 07:41
  • By Davies
Another quick question. I don't have the service manual for this unit. P8000 serial : AT4000240. How do you bleed the brakes? With the engine running or off? It has the wet brake system and we just changed the brake oil in the tank. Any help would be appreciated. Thanks
  • Posted 5 Nov 2015 08:20
  • By Davies
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
