Event codes?
The forklift will not function at all, last event was 128.
  • Posted 25 Jun 2016 05:15
  • By Matd
  • joined 25 Jun'16 - 2 messages
  • Washington, United States
Motor will require removal and stripping on the bench, encoder bearing needs to be removed with a puller and new one pressed into place. Encoder is internal to motor.
  • Posted 1 Jul 2016 20:08
  • By techno_nz
  • Canterbury, New Zealand
How hard with the encoder be to replace, or is it possible to repair it. It appears that water enter the top of the hyd motor from cleaning the battery. This possibly caused something to go wrong with the encoder.
  • Posted 26 Jun 2016 03:50
  • By Matd
Access module not seeing movement of hydraulic motor when it should. Could be as simple as hydraulic lever switch being stuck or motor encoder bad or as bad as hydraulic motor or access module. See if small trouble shooting manual is still under hood back on the counter weight and follow it.
  • Posted 25 Jun 2016 21:43
  • By popeye
Mitsubishi FGE35AT
Aichi RX07B
