event code e151
Please!!!!!!!Can someone please tell me what does the code E151 mean? Thanks!
RAYMOND 102T-F45L
  • Posted 25 Oct 2012 00:29
  • By alonso_reyes
  • joined 5 Jul'11 - 48 messages
  • kyku, France
montacargasmsi@gmail.com
do you have the service manual? i need the service codes and wiring diagrams
  • Posted 27 Oct 2012 05:19
  • By alonso_reyes
  • kyku, France
thank you very much, was the wiring can open 'main contactor coil open
  • Posted 27 Oct 2012 05:15
  • By alonso_reyes
  • kyku, France
harness rubbing or chaffing is usually the cause I see for this code.
  • Posted 26 Oct 2012 10:49
  • By forktech418
  • joined 31 May'12 - 19 messages
Code E151 - Drive Communication Tx Error
Short or open circuit in CAN wiring.
Electrical noise in CAN wiring caused by bad connection, outside
interference, or low voltage (especially while lifting or driving) possibly
caused by over-current or short-circuit. Check CAN wiring. Try driving with
a known-good battery or in a different environment.
Bad power amplifier; ETAC internal error.
Make sure the battery voltage isn't dropping off when powering up (most common cause of code, especially with maint free batteries)
Remove the tiller arm at the drive unit, inspect the main wiring harness for chaff's where it flexes when turning.
Check the brake for a short/open
Check the main contactor for short/open.
  • Posted 25 Oct 2012 08:07
  • Modified 25 Oct 2012 08:10 by poster
  • By patrick_b
  • joined 10 Dec'11 - 30 messages
  • Alberta, Canada
Deborah Baker Deborah Baker
