EVENT CODE C8-3 TY 8FBET18
Hello friends,
We have Toyota 8FBET18 and it shows us the event code C8-3.
We do not have a technical manual for this model, only for 7fbcu and 7fbeu.
Thank!!
  • Posted 13 Dec 2016 01:01
  • By Tecnimaq
  • joined 13 Dec'16 - 8 messages
  • Santiago de Chile, Chile
Best Regards.
David Fuenzalida Barria
administracion@apiladores.cl
Hi guys,
i have the same problem at a 8FBET
can some one give me the reference of the part?
Thanks
  • Posted 23 Feb 2021 03:24
  • By Brunogv
  • joined 15 Dec'20 - 2 messages
  • Portugal
Thank you very much....I will see to it tomorrow
  • Posted 20 Mar 2020 07:21
  • By gr_defkalion
  • joined 25 Oct'19 - 11 messages
  • Greece
ath_syntiritis@yahoo.gr
Yes, its the same error and solution.
  • Posted 20 Mar 2020 07:07
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
hello, is the same solution for a 8FBMT16 ?
Thanks.
  • Posted 20 Mar 2020 02:58
  • By gr_defkalion
  • Greece
Hi forking, cheers for the info sir.
  • Posted 17 Jan 2018 08:55
  • By Juanes
  • joined 27 Mar'17 - 10 messages
  • Bucks, United Kingdom
Switch the truck ON.
Its a SAS equipped Toyota counter balance so it must be switched ON when your jacking it!
Jack up the front & support the truck on suitable blocks.
Lift the forks Up & use a suitable mast prop to support the fork carriage / mast ( depending on mast spec )
There is a black pressed steel cover that protects the underside of the traction motors & hides the sensors - unbolt & remove this cover to gain access to the 4 x sensor.
All 4 sensors are the same part number.
  • Posted 17 Jan 2018 05:47
  • By Forkingabout
  • england, United Kingdom
How do you get to the sensors?
  • Posted 16 Jan 2018 23:06
  • By Juanes
Good to hear it was an easy fix & the machine is working again.
  • Posted 14 Dec 2016 07:00
  • By Forkingabout
Thanks for your help, the sensors were damaged by a blow, we changed them and the problem was solved.
  • Posted 14 Dec 2016 02:57
  • By Tecnimaq
Best Regards.
Thank you very much, my friend, the information was very useful. I will review it and comment on it.
  • Posted 13 Dec 2016 23:16
  • By Tecnimaq
Best Regards.
C8-3 = Drive motor R/H speed sensor OPEN.
Jack the front & block the truck securely, remove the black inspection cover under the front that protects the traction motor speed sensors & check the speed sensors.
There are 2 x speed sensors on each of the traction motor, there all the same part number.
While the inspection cover is removed its worth removing all the sensors one by one & giving them a quick clean to remove dirt / debris from the sensor.
The inspection cover & sensors are also prone to impact damage when the truck is run over solid debris.
  • Posted 13 Dec 2016 08:41
  • By Forkingabout
Taylor T650L
UN Forklift FBR25NQC3
edition #1285 - 11 June 2026
RAEDER-VOGEL
