EV100M no left hand reverse pulse -Clark TM247
Left contactor pulls in but no reverse -ok in fwd. Right side works fine in both directions. Ideas?
-Troy
  • Posted 10 Sep 2011 00:16
  • By troy_m
if the motors run forward correctly, then the cables are not the problem, it is within the contactors or the control wires to the contactors, on this truck.
  • Posted 10 Sep 2011 22:18
swap contactors on failed circuit side from fwd to rev and sounds like you are not getting the polarity required for your reverse travel request, check all cables to motor.
  • Posted 10 Sep 2011 07:58
  • By Huckleberry
  • joined 20 Jul'11 - 29 messages
  • Tennessee, United States
Change out the contactor with a new one,or swap a know good one in and see if that does it contactor is binding up it sounds.
  • Posted 10 Sep 2011 01:24
  • By kevin_t
Kai von Berg Kai von Berg
