EV100 Woes
So I left a big company for a smaller company for more money. Now at the new company I work on lots of older units, lots of ev 100 and its kicking my butt. I have a code 05 on a unit no travel but hydraulic functions. Code five in book is start or brake switch. Brake switch had high resistance in it, changed still had the problem. Any help on where to look would be great, including EV100 documents.
  • Posted 12 Jun 2008 07:55
  • Discussion started by electek123
  • Illinois, United States
yep its either the brake switch or start switch
(and as was mentioned if there are any other safety switches inline with the start circuit)
A handset would be of great help for sure...
start at the terminal strip terminals, wires 6 and 8 i think are the fwd and rev inputs. (TB5 and 6) TB4 would be keyswitch and TB1 is accelerator input.
and of course check your wiring , connectors associated with these circuits.
Also a truck wiring diagram would be helpful.
  • Posted 2 Jan 2014 21:52
  • Reply by swoop223
I would have to agree 100% with what Edward T said.
  • Posted 2 Jan 2014 13:53
  • Reply by jeremy_s
So if you have access to the truck wire schematic that would be helpful. The EV100 looks for the same inputs no matter where it is used but different manufacturers use more or fewer switches in the circuit. At minimum you are looking for a park brake switch, pedal brake switch and start up switch in the accelerator. Some may use a seat switch forbtravel only and some may have incorporated a seat belt switch. If it is a man up unit(like an order picker) it may also have a chain slack switch. Once you have determined what switches are in the circuit and how they are wired a volt drop test starting at the switch furthest from the card and moving closer may help determine your problem.
  • Posted 31 Dec 2013 20:51
  • Reply by badbreaksmech
  • Missouri, United States
houw i ken sent you2 pdf files???????
it is to bick voor mail
  • Posted 31 Dec 2013 19:41
  • Reply by michel_v
  • noord holland, Netherlands
Also you might want your company to invest in a ev-100 handset as it can be used as a dignostic/ parameter checker changer thingy. In other words it would certainly not hurt the cause LOL.
  • Posted 31 Dec 2013 13:17
  • Reply by RCAV8TOR
  • Alabama, United States
I think you can download the manual these days, from Flightsystem's website, but the real answer is to check the inputs at the term strip on the card.
  • Posted 31 Dec 2013 11:13
  • Reply by edward_t
Can you get your employer to purchase the Flight Systems Service Manual??
  • Posted 31 Dec 2013 10:23
  • Reply by Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
