hi nuna checked and clean as a whistle wiring and connctions seem ok distance appears good but is there a set gap i need to check to see if its within a tolerence
thanks nuna will check monday and let you know
Hi Sullyamq,
The code 98 means the steering problem : check the wiring and proximity switch, check the distance from the sensor to trip cam. Open the seat then open the plastic cover under the seat and you will see this proximity switch is located in front of the traction motor sometimes it is blocked by foreign material,... Let me know your checking results
Good luck
