ETV 214 error 115 CONTACTOR INPL
Hi all,
I have a problem with an ETV 214. An error 115 CONTACTOR INPL displayed. I have changed the main contactor, checked the AS4803z controller and it's absolutely ok. The wiring is also ok. Please give some advise.
  • Posted 11 Nov 2014 22:44
  • Modified 11 Nov 2014 22:45 by poster
  • By alexey_s
  • joined 11 Nov'14 - 8 messages
  • Sofia, Bulgaria
Etv 216 error 115 coming we changed contactor but not solved that problem wat will do please help me
  • Posted 11 Mar 2018 20:38
  • By karthick_r
  • joined 11 Mar'18 - 1 message
  • Tamilnadu, India
What do you mean steer unit? The controller or the motor? I have installed the controller from this machine to another one and everything was ok.
  • Posted 13 Nov 2014 17:13
  • By alexey_s
  • Sofia, Bulgaria
If you don't have negative output from steer unit to the main contact its not going to help. I think its your steer unit if there is no negative output.
  • Posted 13 Nov 2014 03:07
  • By elektrodrive
  • joined 2 May'08 - 740 messages
enquiries@elektrodrive.co.uk
If everything is ok, when the machine is starting there is two clicks from contactors.
In my case the small contactor is energising and click once when the code is dialed, but the large contactor is not.
I have ordered one new small contactor but I'm worryed that it will not work again.
  • Posted 13 Nov 2014 00:38
  • By alexey_s
  • Sofia, Bulgaria
There are 2 contactors there is a small one and then the line contact which is part of the emergency stop button. In my case the little one was energising but the main contact was not.
  • Posted 12 Nov 2014 10:09
  • By elektrodrive
Yes the small contactor
  • Posted 12 Nov 2014 07:35
  • By little_forker
  • joined 31 Jul'11 - 82 messages
Which contactor do you mean? The little one before the main contactor on emmergency button?
  • Posted 12 Nov 2014 07:33
  • By alexey_s
  • Sofia, Bulgaria
If there is a negative feed to the K7 coil ( line contractor) try changing the contactor as they are known for breaking down.
  • Posted 12 Nov 2014 07:16
  • By little_forker
Hi mate
Ive just recently had the same issue. As4803 steer unit seemed ok but as it supplies the negative for the line contactor and our negative was missing we replaced the steer unit and reprogrammed it in and resolved the issue.
Check line contactor supply and see if your negative is missing. Check line contact coil and make sure the wiring from the coil to the steer unit is not broke.
Regards
  • Posted 12 Nov 2014 03:25
  • By elektrodrive
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
David Wells David Wells
Chief executive, Logistics UK
National business development manager, Roadpod
Senior vice president, PEAC Solutions
Board director, UKMHA
Elwell-Parker ESI500-36
UN Forklift FGL35T
UN Forklift FGL35T
