Error on display
Toyota 6FB15 loader does not start, a wrench appears on the display and error C0 E0. Can you tell your colleagues what this error means?
  • Posted 22 Nov 2024 17:35
  • By Kserv
  • joined 22 Nov'24 - 6 messages
  • Russian Federation
Service manual found. There are all schemes and an accurate description of the diagnostic and repair procedures.
  • Posted 5 Dec 2024 18:39
  • By Kserv
If possible, give a diagram of electrical units and motors. i will try to figure it out on my own.
  • Posted 28 Nov 2024 12:35
  • By Kserv
Sorry my access on Toyota doesn't have any loaders, all I can recommend is disconnect the ground from the battery for 30 seconds, then reconnect and turn on, should clear error if stays on or comes right back, have issues
  • Posted 27 Nov 2024 07:06
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Toyota 6FBL15-12286 Number: 15-12286.
The problem appeared after the loader raised the maximum weight. after that, it starts more.
  • Posted 26 Nov 2024 14:35
  • By Kserv
  • Posted 26 Nov 2024 14:31
  • By Kserv
Give exact model and serial please
  • Posted 23 Nov 2024 07:14
  • By Matthew_Reed
