Error Messages for Walkie 102XM
Hey i recently received and error code E107 and E108 for my Raymond Walkie 102XM. WE don't have the time to wait for the technical book and not exactly sure it is in the book to order it right now with the company if anyone would be able to help me out with this it would make my week.
  • Posted 6 May 2009 00:07
  • By andrew_r
  • joined 6 May'09 - 1 message
life is tough! better late than never, right?
sorry i couldnt help you in time...., but others might like it!
  • Posted 30 Aug 2012 13:32
  • By derrick_r
  • joined 28 Aug'12 - 16 messages
  • Utah, United States
Derrick_r you are only about 5 months behind on your answer buddy.
  • Posted 29 Aug 2012 02:35
  • By fredz0003
  • joined 25 Feb'11 - 69 messages
Raymond Action
Code E107 - Contactor Off
Reason Contactor probably present but controller could not close it successfully.
Possible Cause/
Corrective Action
Problem with main contactor tips.
* If contactor clicks prior to displaying this code, polish contactor tips. If
this is unsuccessful, replace contactor.
Low voltage.
* Try closing contactor with a known-good battery.
Short in contactor coil wiring.
* Replace contactor.
Code E108 - Contactor Welded or Missing
Reason Main contactor tips probably welded or missing.
Possible Cause/
Corrective Action
Main contactor tips welded.
Open or short circuit in contactor circuit.
* Check contactor, wiring (coil), and cabling.
Bad power amplifier.
summery: contractor problems,
battery problems!
  • Posted 28 Aug 2012 11:13
  • Modified 28 Aug 2012 11:15 by poster
  • By derrick_r
I have a 8900 Pallet Jack and E107 relates to the main contactor it could be lots of things wires loose,tips being dirty, not making contact, take it apart and see the pattern on the tip it should be like a diamond pattern....order tips kit.... look their online sales number online to order and get a part number for the mean time you can clean with contactor cleaner, as for the other code showing C128 always mean something wrong with the handle. (I don't know the differences between this two models but I bet is the same). good luck
Adding to that E107, can cause other faults like undervoltage.
  • Posted 5 Mar 2011 09:17
  • Modified 5 Mar 2011 09:18 by poster
  • By fredz0003
Raymond Action
Thanks and million. The lift solenoid was stuck in. Back in action. Thanks again.
  • Posted 5 Mar 2011 02:45
  • By Scottyb
  • joined 5 Mar'11 - 16 messages
  • Newfoundland and Labrador, Canada
Check the E-stop button and make sure it's not engaged. Disconnect the wires to the lift solenoid and cycle the keyswitch. If it goes away, bad lift solenoid. If not, take a look at the wire harness where it passes through the bottom of the handle. 9 times out of 10 that will be your problem.
  • Posted 5 Mar 2011 01:40
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
I have the same walkie, with (C 28 code) no power anywhere except the handle. Any ideas??
  • Posted 5 Mar 2011 00:56
  • By Scottyb
your battery pack is below 17 volts, the main contactor is welded or shorted, the lift contactor is shorted/welded or the circuit breaker is open. there is a update to use a larger amp circuit breaker. I have had lots of battery problems with these. sometimes cheaper to replace whole power pack than just the batterys.
Cheers...Rick
  • Posted 7 May 2009 05:38
  • By itsfixed
  • joined 7 May'09 - 6 messages
  • Alberta, Canada
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
