Yale OSO30BEN24TE131:
error message
getting error message - STENC CHN. any ideas?
  • Posted 23 Oct 2014 07:39
  • Discussion started by forkdoc
depending on which steering controller this truck has:
EPSIII
you may also want to check the encoder spherical connector that connects the pot to the steer gear shaft. I've seen those break and cause errors like this. The set screws can come loose or the coil in the connector can break. Ultimately the encoder may just be faulty.
APS steering
could be a bad position sensor
  • Posted 23 Oct 2014 22:41
  • Reply by swoop223
Steer encoder error channel count mismatch
Possible causes...
Check wiring to encoder.
Check both encoder output channels using voltmeter; voltmeter should pulse with encoder rotation
. Check for chassis ground in contact with encoder housing.
Check for wiring problems on external 1243 capacitor.
  • Posted 23 Oct 2014 10:17
  • Modified 23 Oct 2014 10:20 by poster
  • Reply by kevin_t
edition #1235 - 19 June 2025
