Error L478 and L241 Linde Reach truck R14-03
Hello everyone,
Can anyone have idea what is the problem of reach truck R14-03 joystick all lever sometimes no functions, make switch off the key and all functions okay...
Sometimes again no functions..
Thank you to all.. Hope have can reply my message problem
  • Posted 29 Nov 2017 05:39
  • By Jorne
  • joined 2 Dec'16 - 27 messages
  • Jebel ali dubai, United Arab Emirates
start whit joystik
  • Posted 15 Feb 2024 17:20
  • By michel_v
  • noord holland, Netherlands
Where is the problem?
  • Posted 3 Feb 2024 19:57
  • By Mito_Ont
  • joined 19 Jul'23 - 2 messages
  • Turkey
Why did the error occur?
L 478
Fault description
uC2 RPM tests
Conditions of occurrence
various tests...(index gives 0 for RPMA, 1 for RPMB, 2 for RPMC)
RPMA(0): The speed output from the main controller (RPMOUT) was not the same as the speed request on CAN (RPMCAN) as monitored by the safety.
RPMB(1): The motor RPM measured on X13:103 (RPMsensor) is not the same as the motor RPM measured by the LAC (LACsensor).
RPMC(2): There is a RPM output to the LAC when the joysticks are not operated (or only lower is operated).
Result
No Hydraulic functions
Possible causes
RPMA(0): There is a CANbus problem
or another illegal CAN device must be corrupting the data
or there might be a fault within the control module
RPMB(1): The speed sensor is faulty (one channel is bad)
Or the LAC is calculating the speed incorrectly - faulty LAC
Or the control module is calculating the speed incorrectly - faulty module
RPMC(2): Possible fault within control module (only if found to be the only reason for truck malfunction)
  • Posted 29 Nov 2017 19:40
  • By michel_v
L 241
Fault description
j/stk 1, ch 2, track matching error
U1 <> -U2 (±10%)
Result
No Reach
Possible causes
defective joystick or cable fault
  • Posted 29 Nov 2017 19:37
  • By michel_v
Libiao Robotics
Kai von Berg Kai von Berg
