Error E-152
Our pallet jack will hold a charge and gives the Error message of E-152. It is only about 20 months old so the warranty has expired. Does anyone have information on the code?
  • Posted 21 Dec 2017 04:44
  • By Fann
  • joined 21 Dec'17 - 1 message
JFann
this kit does away with the white plastic tab and has you install the new harness with a strip of wire loom. p/n 1341147/001
  • Posted 5 Aug 2021 00:34
  • Modified 20 Jul 2023 22:25 by poster
  • By Triggs
Same harness got torn on a Toyota 8HBW23 (raymond) ,, with the little curtis AC motor controller, "1232e",,, same exact part numer 1283206/001 in the harness as well.. Thank you the confirming. I had same code Error E152 after boot showed on small display. Also no line contactor closing at all. Just the error.... ??????
  • Posted 4 Aug 2021 03:36
  • By AL_Ultra
  • joined 4 Aug'21 - 1 message
Keep it 100
FOUND SPRING IN HANDLE CUTTING WIRE HARNESS. PART NUMBER ON TAG WAS 1283206/001
  • Posted 22 Jul 2020 22:49
  • By VIPER
  • joined 9 Feb'11 - 24 messages
  • FLORIDA, United States
had the same problem look at the ribbon wire on the card not the one for the key pad.
  • Posted 4 Mar 2020 00:05
  • By justme
  • joined 23 Jan'08 - 19 messages
E-152 CAN Bus Communication Error
Check wiring and battery condition. The Vehicle Manager isnt seeing the heartbeat signal from the traction amp.
  • Posted 21 Jan 2018 04:54
  • By mjohnson
  • joined 21 Jan'18 - 14 messages
  • Wisconsin, United States
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
Nagano NUL120-6
Autolift E180AT36B-D5-180
Nagano NUL120-6
