Error codes
Greetings to all members!! Anyone knows about error codes E0102, E1307 in Jungheinrich EJC 110.
When switching on displays the error codes and doesn't work anything.
Any thoughts?
  • Posted 28 Jan 2025 03:26
  • By stef_g
  • joined 25 May'19 - 12 messages
  • Greece
Did you solve the problem?
  • Posted 3 Mar 2025 04:33
  • By Alexey_Potekhin
  • joined 20 Dec'24 - 9 messages
  • Russian Federation
In the initial message you wrote that you have error 1307, now you are writing about error 1317. Error 1317 signals that the engine temperature is too high. Most often, the wires break right after the plug at the temperature sensor. The external insulation is normal, but there is poor contact inside the wire. Pull each wire with force, you can do this with the car on. A broken wire will give an error.
  • Posted 14 Feb 2025 17:39
Change the contractor and the battery cables and harness. Working well and Controller output voltage L1, L2,L3 12V. When moving 11V. After a while E1317 error message appears and stop working. When switch off and switch on again operates.
  • Posted 14 Feb 2025 04:14
  • By stef_g
  • Greece
You don't understand. The engine control unit is most likely defective. Power transistors burn out. Check each phase of this block, as I wrote earlier. There should be half the voltage on each phase. If the voltage is different, repair of the control unit or a new unit is required.
  • Posted 10 Feb 2025 06:38
Thank you for the replying!! I disassemble the engine motor and reassemble in other forklift and operates properly but sounds subnormal. No sound from bearing, no error code dislay
  • Posted 9 Feb 2025 20:59
  • By stef_g
  • Greece
Most likely, one of the engine phases is faulty. Measure the voltage between the negative "-" of the battery and the phase on the engine. The voltage should be half the battery voltage.
  • Posted 7 Feb 2025 03:42
JCB 533-105
Ncn 110TH
Ncn 110TH 2015
Esie Cortez Esie Cortez
JCB 533-105
Ncn 110TH
Ncn 110TH 2015
