Error Codes 0172, 0087
I've got a Clark with codes 0172 and 0087. It has a 2.4l engine. Its running rough and will surge at idle. Does anyone have any literature on this unit?
Any info on what these codes mean?
Thanks in advance.
  • Posted 4 Apr 2019 05:27
  • By jorge_v
  • joined 20 Sep'14 - 13 messages
  • Arizona, United States
EVERYBODY needs a little help sometimes.
If your fuel system is Juniper
fault 87--- fuel pressure too low
fault 172-- running too rich, fuel trim lower than expected.
check fuel filter
Regulator output to injectors should be 1600 -3000 millibars.
Clark upgraded the regulator a few years back to a single stage regulator, which resolved rough running, faults, coolant loss into fuel stream and hard starts.
  • Posted 11 Nov 2019 08:12
  • By tom_p
  • Alberta, Canada
fault 87--- Low fuel pressure on gasoline less than 55 psia
Fault 172----Adaptive learn for gasoline engine
above faults assumes a duel fuel PSI fuel system
  • Posted 11 Nov 2019 05:56
  • By tom_p
  • Alberta, Canada
HAVE THE SAME CODE ON A C30CL.. ANY ASSISTANCE CLEARING WOULD HELP!!
WAS ABLE TO CLEAR 3 OTHER CODES WITH THE SWITCH AND PEDAL SEQUENCE BUT NOT THIS CODE...
HELP!!
  • Posted 7 Nov 2019 08:58
  • By OSCARINATOTAY
  • joined 7 Nov'19 - 3 messages
ITS A JEEP THANG...
Hey Jorge, did you ever figure this out? I'm getting the same codes
  • Posted 3 Oct 2019 03:07
  • By Nick_Leabo
  • joined 3 Oct'19 - 2 messages
Linde Material Handling
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
Nagano NUL120-6
SMV (Konecranes) 4545CCX5
