Crown ESR300016:
ERROR CODE
THIS REACH TRUCK FLASHES UP CODE 07 ALWAYS WHEN DRIVE IS SELECTED.TRUCK WORKS AND OPERATES WELL THOUGH.THANKS IN ADVANCE
  • Posted 17 Dec 2010 03:54
  • Discussion started by bruce_k
  • devon, United Kingdom
If the code flashes up as you go through the neutral position. This can be due to wear in all the linkages. The direction switches are closing to late or the traction pot is slightly out and inputing to the control card before the direction switch closes. I've seen customers put up with this for ages when it's not effecting operation
  • Posted 11 May 2011 22:59
  • Reply by julesrobdog
yup its the travel pot happends on our Rd 3000 trucks...the pot need to be adjusted or replaced make sure the metal tab on the pot didnt slip out of its plastic holder..
  • Posted 5 May 2011 20:36
  • Reply by irrk1
In the US, I see this problem on RR3000 reach trucks. I have to assume you have the European equivalent of the same truck with the EV100 motor controller.
  • Posted 17 Dec 2010 10:38
  • Reply by Liftdoctor
  • Indiana, United States
Have seen this a lot. It is a pot or forward/reverse switch problem of a combination of the two. It rarely causes a problem with operation, although it can with a worn pot.
  • Posted 17 Dec 2010 10:36
Lincoln was known to have more than one stovepipe hat, each typically seven or eight inches tall. It is said that hats were important to Lincoln: They protected him against inclement weather, served as storage bins for important papers he stuck inside their lining, and further accentuated his great height advantage over other men.
edition #1130 - 1 June 2023
You might notice a few changes in your newsletter and on our website. That’s because we updated the format last week to make it even easier to read – and to... Continue reading
Brisbane, Australia
Eastern New York, United States
Louisville, KY, United States
GUADALAJARA JALISCO, Mexico
