error code
hi i have a hyster stand up that flashes a intermitten code of 65527 node3 or 5 after changing direction fwd to rev.
  • Posted 1 May 2015 03:56
  • By michigan
  • joined 1 May'15 - 2 messages
  • Michigan, United States
thank you for the help i was able to swap out joy sticks with a working lift an fixed the issue
  • Posted 21 Mar 2018 05:38
  • By chrisha
  • joined 24 Jan'17 - 14 messages
  • Maine, United States
Check the wiring to the joystick. If the wiring is good you need to replace the joystick.
  • Posted 20 Mar 2018 08:17
  • By BREWSKI
i am having the same issue except my lift wont move at all 65527 node 3 & 5 i have changed out controllers an chased wiring i am not getting any communication with the joy stick if i run a no run dia. the horn side shift or tilt wont work dont want to just throw money at this lift can you help?
  • Posted 20 Mar 2018 07:11
  • By chrisha
Thank you that gives me a direction to start in
  • Posted 5 May 2015 00:10
  • By michigan
The error code is- not receiving can messages from RH motor controller and from hydraulic controller
  • Posted 5 May 2015 00:08
  • By BREWSKI
Mitsubishi Logisnext FD25T5M
Airman ENCL045
Airman ENCL045
