error code
customer has a 8FGCU15 with an intermittent shut off - no restart
showing an error code of ES-9 or E5-9
any help would be appreciated
  • Posted 10 Apr 2014 03:31
  • By 67Malibu
  • joined 20 Feb'14 - 18 messages
  • Oklahoma, United States
I'll definitely look at those possibilities! Thank you so much!
  • Posted 4 Jun 2014 08:24
  • By paul10
  • joined 18 May'12 - 15 messages
FO-2 - EHPS Abnormality
Current flow in motor although TMPS is NOT on. Basically the unit is seeing current flow through the steer motor without the unit actually being on.
There is a fault somewhere in your steering system. There are numerous possibilities. Things to check:
Battery voltage
Key switch
Check the power steering wiring
The other checks require opening the PS Controller. Only a skilled technician should attempt it. 36/48 Volt forklifts are dangerous and severe shock can occur. Checking for voltage on wrong terminals can also fry your multi meter as well as the main forklift controller. Hope this helps...
  • Posted 4 Jun 2014 07:02
  • By LTS1
  • joined 18 Dec'13 - 74 messages
can you tell me what the code fo-2 is onf a 7fbcu25?
  • Posted 4 Jun 2014 02:38
  • By paul10
Neither of the codes you have provided are legit. Please check code again and reply.
  • Posted 14 Apr 2014 10:11
  • By LTS1
Terberg RT223
Mitsubishi FGE35AT
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
